Air Intake options for LS swaps in LT1 4th Gens
I'm curious what you guys are running? I am doing an LY6 in my 94 Camaro and have pretty much everything for my build. From my understanding, the 98-02 airbox won't fit under the lt1 hood, so that means I'm going to have to get something fabbed to fit. What did the rest of you guys do? Thanks.
I had a K&N intake from the previous Lt1. I just adapted it to work with my Ls1 swap. I used a 4" silicone elbow along with a 4" to 3.5" reducer. Here is my swap thread.https://ls1tech.com/forums/conversio...q4-t-56-a.html
You could have better options if you get rid of the abs module. It takes up a lot of room.
I'll wait to see where I'm at once the motor is in. I think the current moroso with a round elbow is probably the best route based on your build. Also nice 93, mine should look pretty similar when done..same color and all.
