67 Chevelle - 6.0 4L60
#61
Did you sell off the shortened pan by any chance?
#63
The gauges look great. What about the tach as far as hooking it up? any provisions for a check engine light? I found the gauge kit on ebay cheap like $180. how hard was it to form the lexan and epoxy the panel in? Did you use the factory clear lense over the panel seal it up?
thanks
thanks
I tried lexan but couldn't get the temp right to conform to the mold - Kept getting bubbles in it - Used Plexiglas and worked great - Don't remember what the temp was but I tried a couple scraps before hand.
The plexi panel takes the place of the stock lenz.
#71
back to the top
I wanted to bring this back up to find out if anyone else has done this swap and possibly have or would have changed some things to improve the outcome of the 66 or 67 swap.
#79
First off, glad to see someone already do this swap. You did such a great job and I love the white as well. Car looks absolutely fantastic brother
I am curious where you are at now in the build as well...any pictures or updates?
Also, what is that digital dash cluster? That is amazing looking and I really would like to know what it is. Thank you in advance!
I'm copying you on this, have a 67 Chevelle and I'm doing the LQ4 6.0L but with a T56 transmission instead. Hoping to be able to copy most of your stuff on here and thank you for all the detailed info and pictures. Great stuff
#80
