Going from a bbc to an 07 l92
I picked up a 07 l92 with just under 100000 . I plan on swapping into my 68 Camaro . What is every one running for accessories . I'm going to run a belt driven fuel pump and vac pump . I'd like to run them off the damper on a mandrel drive . Also I'm only running a alternator and maby a water pump off a serpentine . I have a 3 bolt mandrel drive but I don't know what balencer to get . Also is there any thing to look out for ad far as flex plates I currently have a powerglide .
I am sure that ATI has a balancer that you can use with the mandrel drive. Don't know about flex plates cause I like 3 pedals.
Andrew
