Using OEM Chevy truck pump in swap
I purchased an entire wrecked truck to use in my swap. I know I need to upgrade my fuel pump and was planning to use a wahlbro pump. The wrecked truck I have has all the OEM fuel system.
Is it possible to pull the Chevy sending unit and remove the fuel pump and install it into my Dodge sending unit?
You need to provide more information..
Like what year and engine is the wrecked truck. Are you doing any mods to the engine.
If the engine and pump where from the wreck and going in to your Dodge.. yeah.. most likely the pump will be fine.
But wouldn't hurt to upgrade... but an upgrade might be overkill if the engine is stock.
Just a few thoughts...
Wrecked truck is a 1999 1500 with a 5.3. Engine was rebuilt, bored .040 and flat top Pistons installed. Stock cam, stock heads, truck manifolds, Ls1 intake...it's what I would call pretty stock. Might get a cam and converter down the road. Again, I am under the impression a stock fuel pump is capable of supporting those mods.
Theoretically I can just steal the actual fuel pump from the Chevy fuel pump assembly and install it on my Dodge fuel pump assembly.....correct?
Theoretically, the Chevy pump would work fine in the Dodge unit provided that the housing can be modified to fit. The one thing that I was curious was if your Dodge pump is an EFI fuel pump. If it is, it's likely that the existing pump will produce enough pressure and volume to run the LS. Everything that I've found says that the pump usually runs 50+ psi, and is regulated at the rail by a fuel pressure regulator. Since you're swapping the old motor out, you could just run a Corvette/S-10 fuel pressure regulator, and you should be able to achieve enough pressure and volume to run the LS w/ your Dodge pump.
