Bleeding McLeod foxbody problem
93 fox with t56, viper slave cylinder, McLeod master cylinder, and Fox oem manual pedal with McLeod quadrant. I just can't get the damn thing to bleed even with the bleeder nipple being on the master cylinder. I've had someone pump and hold while I let pressure both out of the slave and master. I bench bled the master. I just can't get it to bleed. Anyone have any tips or advice? How did you guys bleed you fox's? Thanks for the help...
