Battery has less then 12v, Cranks but won't start, Is this normal
So the Porsche sat for about 2 weeks. I knew the battery was a little weak. I tried to start, cranked fine for about 5 seconds, About 3-4 attempts, then starter got weak, checked battery voltage it was 11.3v. I disconnected battery and put on charger for about an hour. Hooked up fully charged battery and started right away. IS this normal for these computer controlled motors or do I have something hooked up wrong.
Yea, this sounds normal. You have to remember, your voltage will be lower while you are cranking compared to when it is just stationary. I don't remember the exact voltage, but these ECMs need to see something like 10.2-10.5v for them to even turn on. With the battery weak, it's pretty likely your voltage was dipping below that threshold while cranking.
