Engine stand question
Car's at the body shop finally. Time to clean up and paint the engine and trans.
Got the motor onto the stand but realized I used the lower bolt holes in the oil pan. I need to remove the pan to install the pick-up and windage tray.
What bolt hole locations do you guys use when working on these things? Didn't apear to be 4 obvious locations to use when not using the pan holes.
Thanks!
Thanks!
I wasn't able to upload a pic, but the ONLY way I've been able to bolt three of these engines to stands is buy using the two lowest bellhousing bolt holes on either side.
