Dbw to dbc with 4150tb
Im looking to convert my dbw trottle body to cable using a 4150 tb. Is there any reason i would need the iac for it to run right? I know my ecm doesnt have the stepper motor and i really dont want to buy more credits for a cable ecm. Thanks.
So what's wrong with the set-up above?
You really need an IAC. The 4150 style throttle bodies all use one, and I think you'll have a hard time idling without it.
Do you want the bigger TB because you'r spraying it?
Andrew
Andrew
If it does, then you can make it feel more responsive by playing around with that table.
As far as total flow, I would think it's fine.
Andrew
