LT1 to ls1 with T56 need info on connector 220 and 230 for manual
just like title says, I need some info on swapping a LS1 T56 into a 97 camaro that was manual. I have pretty much everythhing figured out exept the diagrahm I have is for a auto car and does not tell you where to put the wires of the Manual. I assume I use wire out of 220 G instead of 220C and put it in 220E, and then take wire 220B and put it into 230H instead of 220D. I cannot get any clarification on this and I do not want to jack nothing up and I want the clutch switch to work on this car so that it will start when pedal is pressed and not start when its not and also provide power the the T56. I want proof this is what i need to do before I just try it.
