87 Fox Body LS Turbo
Old 01-30-2016, 09:49 AM
  #281
Steven32's Avatar
Just a little delayed for more updates. Decided that it was best to have the fitting for the turbo return welded to the oil pan instead, so that took some back-tracking.
Had to remove quite a bit in order to get the pan out and have it welded. But that's all being put back together this weekend.
Old 01-30-2016, 12:24 PM
  #282
jaywill's Avatar
Old 02-02-2016, 08:21 PM
  #283
rpturbo's Avatar
I am curious, what ceramic coating product did you use, or, did you have your parts professionally coated by someone? It sure looks nice, and I am looking for something like that, that hopefully, will hold up!
Old 02-02-2016, 08:25 PM
  #284
Steven32's Avatar
I had the parts professionally coated.
Old 02-06-2016, 11:25 AM
  #285
jaywill's Avatar
WHERE did u get the catch can set up and what ecu r u running ???
Old 02-06-2016, 12:05 PM
  #286
Steven32's Avatar
This is the catch can that I have.
http://www.ebay.com/itm/VMS-ALUMINUM...Y0odnA&vxp=mtr
The ECU is a stock truck ecu from a 2002 2500
Old 02-06-2016, 03:47 PM
  #287
jaywill's Avatar
thanks !
Old 02-06-2016, 05:35 PM
  #288
Steven32's Avatar
thanks !
No problem!!!
Old 02-24-2016, 03:07 PM
  #289
Steven32's Avatar
Little update....not a lot left.
Turns out the fuel lines I bought aren't PTFE lines, so we ordered new ones to replace with. Those should be here next week.
This weekend the steering rack, shifter cable, and a couple other little odds and ends things will be put back on. Other than that, all that's really left is all the needed wiring (gauges, pumps, fans, ecu, injectors, etc.).
Very excited to be this close.
Old 02-24-2016, 03:12 PM
  #290
jaywill's Avatar
mabe i day i'll be that close ...lol
Old 02-24-2016, 03:20 PM
  #291
Steven32's Avatar
It will come! It's always something that's popping up with this car, so I'm hoping that won't be the case and it's actually almost done
Old 02-25-2016, 02:36 AM
  #292
jaywill's Avatar
BTW..where did u get your water pump t-stat housing ?
Old 02-25-2016, 08:21 AM
  #293
Steven32's Avatar
On Ebay, this is the one I have.
http://www.ebay.com/itm/CBM-10610-Bi...-/231525462379
Old 02-25-2016, 02:12 PM
  #294
FrossB's Avatar
At the home stretch!
Old 02-25-2016, 04:40 PM
  #295
jaywill's Avatar
Thanks
Old 02-26-2016, 02:04 PM
  #296
Steven32's Avatar
Definitely. Very anxious lol.
Thanks
No problem!
Old 02-27-2016, 07:49 PM
  #297
matt_u's Avatar
I currently have plans to do a very similar build in my Fox but with a 5.3. Do you have any more information on the wiring?
Awesome build btw!
Old 02-29-2016, 01:06 PM
  #298
Steven32's Avatar
Awesome build btw!
I don't have any info on that at this time. That's one of the last things that needs to be done and I'm having my friend's shop tackle the wiring part of it since he's doing the tuning too.
Thank you!!!
Old 03-06-2016, 08:10 PM
  #299
Blackhatch's Avatar
Subscribing.
Old 03-07-2016, 11:42 PM
  #300
Austinbelair's Avatar
Damn, I might need your help with an NA 5.3L swap into an 89 Coupe I am thinking about buying. I'm in Austin as well.
Quick Reply: 87 Fox Body LS Turbo
