LS3+4L65e in '61 Chev-> S&P trans mnt, mount where?
I'm puttin ga 430HP LS3 with a 4L65e into a '61 Bubbletop.
I have a trans mount from S&P. No info on whether it should be mounted at lowest part of frame, middle, or higher...
I called, and they said I need to drop the engine and tranny in and measure the angle of the tranny to determine. But to do that you should have the car on level ground to take the measurement.
I"m thinking about mounting at lowest point, then ultimately if it needs to be higher, put in spacers between the pad and mount.
Any comments or ideas?
