e38 with dual electric fans
Is there a wiring diagram for this? e38 came out of an 08 express 3500 with a mechanical fan. As I understand it, I can add pins to 17 and 58 on the X1 connector for relay control. This would be for a 1994 Chevy b body swap.
I found a diagram for an 08 escalade that uses 4 relays. I am planning on integrating the factory 94 underhood fuse/relay box. The box has 2 relays for the cooling fans. Any help??? THANKS!
A sexier way of doing it with the E38 ECU is to control the fans via PWM:
http://www.lateral-g.net/forums/showthread.php4?t=40215
Andrew
Andrew
You can actually use a PWM module from a Chrysler minivan if you're on a budget. The module is around $30 new at the parts store and even less in the salvage yard. PWM fans on a budget.
Hmmm, the pwm is very interesting. Does anyone have the diagram for an e38? I think its still pin 58 for the pwm, but what about the ac? I have a factory pressure switch that uses the same connector as the vette I believe. What are the chances my sensor is compatible? Its the same 5v style high/ low/ signal style.
Also, seeing as I have to convert to manual ac (which I still have no idea how to do), that sensor wouldn't get used anyways?
As far as budget and the chrysler controller....it started out as a budget build. That turned into a different car and different engine/trans/axle, etc... But if the chrysler controller does the same thing....
My car now with the lt1 had 2 relays and 2 40amp maxi fuses for the fans. I know the pwm controller doesn't use a relay. I believe both fans are each 150w. Will the chrysler controller do both fans on one 40 amp fuse? Should be no startup amp spike being pwm? Thanks for the help!!!!
I can't speak for the Chrysler fan controller, but the C6 fan is 400w, so the C6 fan controller will easily handle both of your fans. The C6 fan controller range is 5-90% duty cycle. I am using this combination on my 67 Cougar build, but with the Holley Dominator ECU.
Andrew
This is how I used on an E38 with a hi/low speed fan should work for two fan setup. I have not added the third relay for the AC yet, but it has been working fine. I don't think my fan has ever been required to go into hi speed other than when I was testing the system.
I am going to go with the c6 pwm controller. Car originally had 1 40 amp maxi fuse and 1 relay for each fan. As far as I know the wires are 14 gauge. Will one wire on a a single 40 amp fuse (that was originally for one fan) run both fans safely through the controller?
In the picture that I posted you can see the connector that I wired. It is a Metri-Pack series 480 3 cavity connector which is rated at 42 amps max.
Andrew
Andrew
Andrew
Why is adding complexity of a PWM controller better? I will soon be wiring 2 fans up with a E38. If the E38 can control 2 fans with dedicated outputs then why the fuss?
With my doors and windows closed and exhaust rumble I don't hear my fan on high (I only have high speed wired). I have AC so commonly I do have the cab shut tight.
Still, many folks are Hot Rodders here. If you can make it better why not? And it doesn't cost much more than a multiple high current relay setup.
I may make this conversion one day when I'm bored
Doug
Andrew
