1979 ford supercab swap questions
I'm planning on building a 70's ford supercab into a mild offroader, hunting wagon, family camping rig. I want to be able to drive this thing long distances on the road, so it has to be reliable and have plenty of power.
I'll be running 38"-40" tires and one ton axles.
I'm on the search for an engine/trans combo now. What would be you're recommendations for my swap? I've been reading and searching, but haven't really found the answers.
I was thinking a 6.0 with a 6l80e would be the best setup and cheaper than going with a 6.2. Or should I stick with a 4l60/80e?
What donor do I need to be looking for?
I want to be able to adapt the a/c from the donor too.
Thanks in advance for any info.
I would be searching for a 3/4 ton pullout. 6.0 4l80e. Relatively cheap, the 80 is gonna handle the abuse of big tires/drivetrain stresses absolutely stock. A mild cam/headers on a 6.0 will make solid 400hp reliably. Obviously you could mod from there for more power if desired.
