OE Style Electric Fan Ass'y For 1969 Camaro with Griffin LS Radiator?
I assume you might have an LS1 or LS2 from a GTO based on your screen name...could have that wrong though. If the GTO radiator is too big for your car, I'm sure there are other options.
If you can mount a stock C6 fan assembly on that radiator, I would do so. That fan is a beast and is not super expensive. You can also use the C6 fan controller and run the fan in PWM mode if you have e38,e40, or e67 ECU. My Cougar build thread has a ton of pictures of the fan and radiator.
Andrew
Andrew
