88 crew shortbox project more door
All from pieces nothing was together as is now. 88 R20 3/4 ton cab, 86 shorbox, 89 suburban doors, interior, gas tank, suburban grille/support combo, new aftermarket inner/outer fenders, new reflection split cowl hood. Frame is combo of 87 suburban/ 85 pick up 18 foot 7 long end to end no bumpers on. Rear end 78 suburban camper special 12 bolt 3:73 posi. Motor 06 5.3 with 01 dbc set up, tranny 01 4L60E, ebay motor mounts & headers. Shaved the truck intake cleaned painted motor. All stock changed nothing stuff & go with it. Wiring in it is 89 suburban tbi injected with garbage removed. I did silverado harness and tied that in. Should make awesome truck, only regret not doing as a 4x4. This been in works since summer 06. Just sold off stuff and figured better get going. It went from 305 tbi to 350 tbi to now 5.3. never driven it. Still got interior to install. You can see my cavalier fuse panel/pcm homemade bracket.
as Im working on now in spare time
driver side header lots of room, steering pump clears well
passenger side header clears by bout 1/2 to 3/4 inch from frame stand
