08 e38 ac wiring
08 e38 ac wiring
Getting closer to finishing the harness on my ly6 94 fleetwood swap. Searching for hours, I am more confused than ever on wiring the ac. Compressor is a relocated sanden 508.
I am using a c6 pwm fan controller, so I think I have the fan part. The high pressure sensor wiring plugs right into the fleetwood sensor on the high pressure line.
Does the ac request from hvac control go through pressure cycling switch on drier and then to compressor relay? Any way to wire it into pcm for idle bump?
Here is the 94 fleetwood diagram. Thanks for any help.
