5.3 / 6.0 harness question. Oil pressure sender.
Used the wiring harness mod from lt1swap.com about a year ago and got 80% done and threw it in a box. FF to this week. Laying out the harness and I don't see a plug for the oil pressure sensor at the rear of the block. Is this needed? I checked the red/blue connector layout and see nothing for the oil pressure sender labeled.
If this is needed can someone give me the pin number on either the red or blue connector where this should be connected.
Thanks
Thanks
