1971 impala custom ls1
MY 1971 IMPALA CUSTOM COUPE
https://ls1tech.com/forums/conversio...errerid=280759
1998 TRANS AM WS6 LS1 STOCK
EDELBROCK INTAKE
HOLLEY STRRET AVENGER 670 CARB
HOOKER LS MANIFOLDS
PAINLESS WIRING
GM CORVERSION OIL PAN KIT
DUEL FAN FROM 1998 F-BODY
LOKAR LINKAGE
98% DONE
needs the exhaust hooked up but first......
NEED HELP WITH SHIFT LINKAGE
my linkage seems it won't go threw all the gears or into park at all because of the manifolds i got. its really really and i in really close. I'm going to try to jimmy rig the linkage and try to make it work but if ANYONE HAS ANY suggestions that would be a life saver.
ps i already ordered BOTH LOKAR shift linkage gifts both lokar part number
#ACA-1800
AND
#ACA-1804
both seem to not work for me as i can't get the rods bent in the right shape without messing up and having to buy another (I've bought like 4)
and the other kit is for a aftermarket steering column which mine car and app WILL not work.
any ideas ???? at all?? please help i will be posting pictures of all
and any comments would be super and thanks for looking
EDELBROCK INTAKE
HOOKER LS MANIFOLDS
PAINLESS WIRING
LOKAR LINKAGE
98% DONE
#ACA-1800
AND
#ACA-1804
&update
as you can see the stock shift linkage goes to the left slightly and moves up or down with gears. can i just the linkage or bend it to work or do they make something more specific that i can buy to make this problem go away
update :i went to the junkyard and got a few extra linkages out of some GM turbo 350 A-body cars and a truck just incase
Okay, thanks a ton!! ill give that a try it seems to have a little and i mean little room for adjustment on the linkage. but i will check out Kugel as well because i think that is the way i probably will have to go....unless i want to modify lol
i just looked online it seems i have the same looking kit from locker and i have yet to make it work...hmmmm
ill try a few more things and come back with a update!
