Vintage Air Conditioner low mount with Corvette balancer
I have a 68 Camaro. It has an LQ4, upon which I've slapped a CTSV/ZL1 blower. I have the CTSV/ZL1 balancer, which is the same belt spacing as the Corvette. I just ordered my Gen IV kit, with the Sanden 508 compressor. I got the Alan Grove 141811 bracket. The idea is to run the belt on the inner groove (which is now running nothing). It has to be a low mount because the upper mount will interfere with the blower. But, despite that I have my conversion brackets on the front position, I believe the compressor will contact the motor mounts. I don't know yet, because I am waiting for the kit.
Does anyone know if the SD508 will hit a frame or motor mount if you run it on the first groove of a corvette balancer? Is there any other solution, such as an SD7 compressor or bracket?
Check out my build thread , u'll c that I used Alan Grove low mount AC bracket & I positioned the motor 1.25 forward from stock location & I cut some of the crossmember 2 gain clearance & it's close 2 motor mount but mine cleared. I have the SD508 compressor.
I hope that works for me. The vintage kit should be coming this week. My engine is only 1" forward, so I may hit the frame mounts. I don't want to run the sd7. It doesn't have the cooling capacity. Is there a high mount kit that works for the LSA setup?
That I don't know but it won't hurt 2 try installing it , but remember that the ports where the line screws onto the rear side of compressor. It's close @ 9:00 position , so mine might hit the subframe , but if it does , I planned on drilling thru the sub frame & weld a tube to the hole cut out for strength & run lines thru the tube & connect it to compressor. It might be different but we share the same sub frame. Good luck & let me know how it worked out 4 u.
