F1a 5.3 swap 04 mustang questions
I'm in the middle of swapping my Mach 1 and I am having issues with my headers clearing. What are you all using. I have heard 5th gen Camaro manifold will work. I don't want to swap k members. Currently have a qa1. Please help
I have kooks for a Foxbody right now. But with the qa1 K member and UPR swap mounts the engine sits to high and headers hit floor pans. Also driver side hits steering rack buckle for steering shaft
the knuckle is easy, your column can be adjusted by dropping down a little. under your dash you will notice bolts that you can use shims to drop it down a little. I had to do the same thing. I used 2 washers on the front (closer to firewall) and 1 washer each stud closer to me. They sell shims also for the k member. I think there are 3 sizes? 1/4" 3/8" and 3/4" I think. UPR might have them. I originally used 1" spacer under my k member (use longer bolts) I wanted more under hood clearance.
UPR mounts, if you can fabricate a little, just get rid of the plate, its 3/8" thick. I just cut and extended that mount. Its just 1 tab that needs to be done and then the plates are no longer needed. I'm surprised they havent done it that way.
