C5 corvette tac module question
Old 10-28-2015, 02:30 PM
Broon72's Avatar
Default C5 corvette tac module question
I'm doing ls swap drive by wire in my chevelle. I'm using ls2 silver bladed throttle body, and c5 corvette pedal. I need 12578953 tac module, I have found 25311783 modules. I think they were same tac module with just one being an older part number. If anyone knows let me know found a deal on 25311783. Thanks
Old 11-03-2015, 07:59 PM
Broon72's Avatar
Anyone? Know
Old 11-04-2015, 12:25 PM
NorCalAnthony's Avatar
Not sure on the different part numbers but the TAC you want should have the all plastic body and mounting tabs. If it has a plastic body with a metal mounting bracket/tabs that's a different style (03+?) and probably won't work for you. Hopefully the one you found a deal on will have pictures so you can at least check which style it is before you drop the coin...
Edit: I just Google'd the part numbers and the new replacements from GM list both numbers as prior part numbers so you should be good to go.
Quick Reply: C5 corvette tac module question
