Evap Emissions Purge Solenoid - Used on conversion?
Several questions, all related:
I'm installing a crate LS3/430 in a '61 Belair Btop.
Will I need to use the evap emissions purge solenoid, and if so, then get a charcoal cannister? Or can I discard it? If I can discard it, do I need to plug the hole it mounts in on the manifold?
It is in the way of my compressor mount from March. If I need to use it, is there a way to have that function relocated?
Pic of the item discussed:
