L99 Body/Fuseblock connector info
I am swapping a L99/6l80e into a 1985 Chevy C10 Truck. I have a lot of LS swap experience, and usually use an after market harness. I have manually wired up LS3 and LS1 ECU's as well. Having said that, this is what I am looking for.
We are using a dropout from a 2012 Camaro. It has an almost completely stand alone harness with just two connectors that would connect to chassis on the car. I am assuming one is to the Fuse Block, the other I am assuming goes to the inside cab stuff (throttle pedal, OBd2, Instruments, ect).
Does anybody have a diagram for the pins on these 2 connectors? I am thinking from a 2012 camaro, but i assume this is probably similar to other GM apps. I could spend a week with an ohm meter, but I am hoping there is something out there. The pic attached shows the 2 connectors. Thank you,
Scott
Scott
This should help out.
Forward lamp harness connector and underhood fuseblock harness connector
http://lt1swap.com/2010camaro_x102.htm
http://lt1swap.com/2010camaro_underhood_x3.htm
