Engine has Hard start and sputters and bogs when you mash on the gas
Having a little issue here, I put a LS engine in my 1971 Camaro and installed a Holley Terminator LS 550-609 Kit. I programmed it with a LS1 / 4L60e base and inputed my specific parameters and did a self learning.
Car idles fine when warm and sounds great. But on initial start up I have to "give" it gas like an old carburated engine and baby it until it starts. After that i have to hold the gas in to keep it from dying. Once the temps goes up it will idle on it's own.
But after that if I mash on the gas the car will bog and spurt a little until I let off the gas. But if I ease into it.....it's fine.
Any ideas? I made sure to use all new delco sensors and what ever the holley install manual suggested to use. Basically all of the gaskets and sensors are new and I tried to pay attention to torgue specs to insure no vacuum leaks.
Brake booster and hoses are new as well
Fuel system is new and I installed a pressure sensor on the fuel rail. Looking at the screen when running the car it holds constant pressure. Around 57-58 psi.
I am using the firmware that came pre-installed on this system, hadn't updated that yet.
Could it be the IAC valve? I am running DBC and and contemplating converting this system over to DBW to keep it simple and not have to deal with those two sensors on the throttle body.
Here's a list of what I have on my motor, maybe someone can see something I don't. I just copied it from a spreadsheet i keep on hand.
Part Part # or Name
Engine 2004 Silverado 5.3 Long Block (Stock)
Transmission 2004 4L60e (corvette servo) Stock Torque Convertor
Coils Stock LS1 Camaro
Spark Plugs NGK TR55
Plug Wires MSD
Injectors Stock LS1 28 # 0280158931
Fuel Rail Stock LS6
Fuel Pump Spectre Fuel Tank and Pump 2nd design
Fuel Return Corvette Fuel filter regulater
Intake LS6 Intake with LS6 PCV System
Intake Gasket Fel-Pro 92438
Map sensor Delco 16212460
Throttle Body LS1 w/Brown spring (Brand new)
Throttle Body Gasket Fel-Pro 61069
IAC Valve BWD 31033
Exhaust Manifolds Hooker #850 1HKR
Exhaust Manifold Gaskets AC Delco 12617944
Exhaust 2.5" Pypes SGF11 w/ Street Pro Mufflers
Lower Radiator Hose
Upper Radiator Hose Gates 22352
Water Pump AC Delco 252-846 Tapped for Steam Vent
Valve Covers Stock 2004 GTO
Valve Cover Gaskets Fel Pro VS50504R
ECT Sensor AC Delco 213-4514
Knock Sensor AC Delco 213-3521 (2)
Knock Sensor Harness Dorman 917-033
Oil Pressure Sensor AC Delco D1846A
Air Cleaner Temp Sensor AC Delco 213-243
AC Bracket Holley 20-134
PS Alt Bracket Holley 20-135
Belt Tensioner Dayco 89337
Belt Gates K060990
Brake Booster Vacuum Hose AC Delco 176-1708
Alternator Large Case 145 Amp GM 15754097
PS Pump GM 26120639 (Aluminum)
PS Pulley Dirty Dingo 5" Pulley for LS Camaro
PS Reservoir GM 26046502
PS Reservoir Bracket GM 125552222
PS Reservoir Cap GM 10317982
PS Reservoir Hose GM 15907878
Engine / Transmission Control Holley Terminator LS MPFI 550-609
Part Part # or Name
Plug Wires MSD
Fuel Rail Stock LS6
IAC Valve BWD 31033
Lower Radiator Hose
Belt Gates K060990
the IAC will keep it from idling and starting but not affect wot, my car did a very similar thing when I had a vacuum leak, hard to start, ran good when eased into it but at wot it was as if I was hitting the brakes. look at fuel trim see if youre running lean, which means your fuel trim should be at max rich
