Air intake tube for LS1
I need to make a set up for my air intake to hold my mass airflow sensor and to hold my air temperature sensor. I don't want to break the bank. I'm not looking for something expensive right now... just to get it moving. I wanted suggestions on homemade or reasonably priced ones that would work for my application in my 67 Camaro. Any ideas are appreciated.
You could probably buy a silicone 90 http://www.ebay.com/itm/282070604278...%3AMEBIDX%3AIT and a filter http://www.ebay.com/itm/381493887051...%3AMEBIDX%3AIT and a piece of PVC pipe. Scuff it and rattle can it black.
I used a truck 85mm 5 wire MAF that has the IAT sensor built into it. Intake Hoses has 2 nice adapter hoses to go from 4" down to the MAF inlet and outlet sizes, check their site. They'll have everything you'll need except for maybe the filter, I don't remember.
Thanks for the posts. EastTnZ28.. so your saying use the 90° and then put the mass airflow and then a couplink and then a piece a straight pipe in the filter and drill a hole for the air temperature sensor..in that order?
ebay 4" dia x 24" aluminum tube with 45 in the middle; cut to fit on the air cleaner end; TIG in maf fitting; 90 degree silicone ell from Jegs. Rattle can with bed-liner black. Be sure to sand smooth where the clamps go to eliminate leaks that will set off a check engine light.....don't ask how I know.
I used 4" silicone 90's and couplers I got from siliconeintakes.com along with the spectre tube to mount the MAF and stopped by the guy that is going to do my exhaust (real soon I hope) and asked him if he had a piece of 4" exhaust pipe I could buy from him. He gave me a scrap about 20" long that was plenty for what I needed for free. Capped it off with an AEM filter.
Rock
Rock
