65 Chevelle Swap pictures
Originally Posted by stealth71
Why the 42lb injectors? Can I get a pic of your clutch mounting if possible?
Your post has me thinking of doing a LS1 swap into my 65 chevelle. What are you doing for exhaust as far as headers go? Did I miss that in the posts somewhere?
#35
More Pics Guys!!
ENGINE GOING INTO THE CAR!
ENGINE IN THE CAR
Street & Performance Motor Mount Adapters
FAST 78mm
Intake/fast 78/Street&Performance (MAF/Filter)
ENGINE IN THE CAR
FAST 78mm
#36
Did you use the Street and Performance extra offset (+1" longer) mounts or the standard set? I just got my shortblock for my 1970 El Camino and will be doing the same thing shortly...
#37
I am not sure what mount it is for sure, i called them and told them 65 chevelle and that is what they sent me.. For reference the bottom hole of the factory chevelle mount, uses the bottom left bolt of the ls1 mount (drivers side)
#39
Originally Posted by 67RSCamaroVette
well your '67 sucks. i knew i'd ruffle some feathers..
if it turns out anything like this, you're a-ok in my book..
/hijack
olly
/hijack
olly
#40
Originally Posted by pist0lpete
I can't wait to see what the fit looks like once you have the accessories on the engine. That is my main concern for my swap.
Hopefully I can get that far within this next week and get some pictures of that up on here. When I originally had the motor in the car all the accessories worked out quite well (im not runnin a/c) waterpump/alternator/powersteering
