95 Camaro V6 conversion to 99 LS1
I have a 95 camaro and am in the process of installing a 99 LS1 into the car. I removed the V6 thru the bottom along with the subframe and was starting to install the LS1 onto the sub frame when I discovered that the engine mounts from the LS1 don't fit the subframe like the V6 mounts did. I don't want to botch this.....any suggestions?
Hey thanks. I'll let you know how I do? The K frame or sub frame is what I'am looking for now on car parts. Everything else I have. Six speed, all wire harnesses required, lingenfelter headers, SLP loud mouth exhaust. Just need to get the engine in! More later.
