C-10 5.3l/4l60e
C-10 5.3l/4l60e
looking for a wiring diag or pin out of pcm for a 2004 tahoe/4l60e. i am converting it back to cable tb also.
will i need to flash my pcm with a truck file that uses a cable tb? also then will i need to re-pin the pcm to match that years pin out?
thanks in advance!!!
edit... i have already got the tps and iac pig tails. just got to figure out were to pin them in to the pcm.
man, i love your camaro i am wanting to do the same car/same buildup and i'm looking at an '80 i'd like to front clip swap on to look the same. what year/style front end is that? (70-73 obviously, but ... i like that bumper and 2-headlight setup)
i can't help you with the pinout, but here's a bump for you. i didn't know you were a member over here too
