2210 pin out question /93-97 Camaro
C210 pin out question /93-97 Camaro
I'm installing a LS1 in my 94 Camaro and can't find the pin out for connector C210. It's a flat 4 pin connector. I've looked in my GM Helms manuals for both 94 and 97, they show the connector but don't have a pin out. Of the four wires I've identified 3. They are:
purple wire: starter sollinoid wire
blk/wht wire: ground
orange wire: PCM battery power
There is also a red wire I can't find out what it does. I've powered up the car and there is no power on it either from the battery or ignition, it also don't have a ground.
Any help would be appreciated.
Re'
Re'
According to shbox.com, it should be grey.
1994
Cavity Wire Color Description
A Purple Theft deterrent relay to starter solenoid feed
B Black/White Ground feed to fuel pump relay
C Orange Power feed from PCM BAT fuse to PCM
D Grey Feed from fuel pump and fuel pump relay to prime connector
Kevin D.
1994
Kevin D.
