Putting 99-02 fuel pump in 95 Z28 ?s
I am looking at putting a newer fuel pump with regulator on my 95. Will the pumps do a straight swap over? I didnt know if they had the same number of wires going to them or what. I am wanting to get rid of the return style system is what I am going for so i only have to have 1 line running to the engine bay. Thanks in advance guys!
u can mount the c5 fpr, and run 1 line to a 98-02 fuel rail
the fitting should be the same for lt1 feed line to rail, it was on a 95
firebird i intalled a ls1 engine into. the lt1 fuel line snapped right in to a 98-02
ls1 fuel rail. using a c5 fpr and walbro pump
sawzall wielding director
You don`t want to swap the fuel pump.....can o worms.
The 99-02 uses a plastic tank and the fuel pump/sending unit is not a bolt in for your tank. You could swap to a complete 99-02 tank.....but if you still have the 95 fuel gauge it will not hook up because GM changed the resistance of the sending unit.
The simplest solution would be to get the 99-03 vette FPR/filter and then use the single line LS1 fuel rail. The vette FPR/filter can be found for under $40 and you will be able to reuse your LT1 tank and lines.
ok 1 final question. There are 3 lines coming out of the lt1 fuel tank. Only 2 places to plug lines into the vette fpr/filter. What do i do with the retuen line?
the c5 fpr has a return line, use existing lt1 return line for the c5 fpr back to tank. the other line is connected to charcoal canister thing located behid gas fill door, leave it alone
the c5 fpr has 1 inlet and i out let line. pressure and return.
3rd line from tank is emiision/vent line
ok cool deal. Thanks man!!! Does anyone know the part number for the 99-03 vette fpr/filter? Thanks again to everyone that helped me understand this!!
you could just ask for a fuel filter for a corvette..lol.
btw, you will need the quick connects to plumb this in.
im currently using the corvette filter also.. but on some of my other swaps, ive just put a regulator at the end underhood, retaining the stock feed and return.. then run one line from the regulator to the fuel rail
you do not, and NEVER have to swap to the OEM vette rails with a return...
Any idea where I can get the quick connects?
end result is a hardline with a few inches of flexible line and quick connects.
if you can search my name in the conversions/hybrids section, i know i posted pics of mine.
ok, i searched and found a pic of mine...
in the upper right, is the end of my return that goes to my factory return for my car (91 fbody)
below that, is the factory line for my fuel feed.
as you can see both of these lines have flexible lines and quick connects swagged on the end where it connects to the new fuel filter.
in the middle, is a vette filter/regulator.
on the other end, is my stock feed line, with a quick connect fuel line brazed onto it.
your stuff will be similar.. not identical, but similar.
