79c10 procharged ls1= need lots of help!
the garage had my truck for almost 4 months and got some of the truck wired. they finally told me they could`nt finish it. so.... now i want to try to finish it myself. i know i need to check to see what has`nt been done. has any of you done one of these, that maybe walk me through this so i can get this thing to fire. i need to know what i need to first, on so on. any help would be greatly appreciated.
do you know what has been wired? did you use an old harness or were they trying to make a new custom harness? theres lots of wiring you need. if you use a old harness theres not alot to hook up really. be creative and do what you want with it. there is obvious things that need power so you might need some meters to read voltage etc. pics would be nice to, to try to see whats been done so far.
sawzall wielding director
Did you check out post 13 of the FAQ sticky? Theres lots of wiring info in there.
We do need some more info on your combo to be helpful. IE: what year make, and model the wiring harness is from if its stock, the same for the PCM if they are not from the same car, if your using electric fans, keeping the emissions equipment, etc.
i am also doin a similar project, but im tryin to do it myself using the stock vette harness.i tore off all emissions,bought a dual fan radiator,i think ill just try and splice some autometer guages of the harness. what do i need to keep on the motor and what can i ditch, where to start? please help
