Anybody with a C3 Corvette using stock AC comp?
Old 09-02-2007, 09:03 PM
myoriginal77's Avatar
Default Anybody with a C3 Corvette using stock AC comp?
I've finally got the motor in the car (1977) but the stock AC compressor is going to be a tight if not impossible fit.
Any ideas ? I searched with no luck.
Thanks,
Happy Labor Day,
Frank
Old 09-03-2007, 08:32 AM
nitrovette's Avatar
Frank youll probably have to swap to a newer style compressor and either buy the aftermarket bracket for a/c to mount it up high or fabricate your own bracket.When i did the swap i left the a/c off and now im removing the whole heater a/c box and going with aftermarket underdash setup and ill make my own bracket for the a/c.
Old 09-03-2007, 02:18 PM
Thanks for the reply. I was hoping to use the factory setup but if I can't I can't. Which aftermarket set up are you going with?
Thanks,
Frank
