Is there really a huge benefit to getting an 01-02?
I know I've read that 01-02's are the best to get because of mileage, better oil pump, more stock power, etc. But is there any reason I shouldn't save a little money (I'm on a budget) and get a 98 or 99 and change the oil pump?
no, the only real thing to watch is milage. I wouldent get a pull out with 100K and plan on just using it. --> unless its dirt cheap and then you can afford to rebuild it?
I would say the biggest advantage to the 01/02 engines are the rod bolts. The 98-00 engines had weaker rod bolts that have been known to fail when the engines are revved to high(to make max power with a bigger cam for example). However, since you would already have the engine out it would be pretty easy to just take off the pan and change the rod bolts out.
Correct me if I'm wrong, but I think the 98-99 ls1's have a more aggressive cam than the later models. But the later models have the LS6 intake(01-02) and the better flowing heads.
But yea....there's no reason to not buy a 98-99. LS1 is an LS1...In some cases you are better off with an earlier model engine. For example I used a 98 in my swap because I need to have the egr to pass emissions.
Actually, 99-00 have a bigger cam both duration and lift than the 01-02. If you put the LS6 Manifold on the 99-00, then you have the best of both. I believe the 97-98 do have a different ECU set up that is not as programmable or as widely interchangable as the later model. As others have said, they are all good, just shop for mileage.
Pat
Pat
Well I just called around a couple places. One place has an 01 with 30k for 4500 and on 02 with 65k for 3700. The other place I got ahold of didn't have anything less than 96k, it was a 98, and he wants 3800. The only other place I have a number for isn't open yet so I'll try them on my lunch break. Taht 01 with 30k looks like the best deal so far.
I drove several 98-00 LS1 ( T/A, Camaro) and noticed that the 01 + had more usable torque and didn't sacrifice anything on top ( perhaps helped by the LS6 manifold.) The heads were unchanged. The 99 T/A & SS I drove really felt soggy down low. So I settled on my old 01 SS ...my first brand new car at the ripe old age of 38 , back in 01. Wished I never sold her... but I like the 74 better...most of the time.
"Iheartturbo" what are you building anyway? If you plan on doing a 240sx, you should entertain the idea of a L33. 05-07 1500series 4X4 trucks....5.3l, aluminum block, 310hp, and way cheaper than the LS1. If weight is not an issue, you can never go wrong with a 6.0l. L92 heads, big snail, etc, 600hp is fairly easy to get. But for $3800, you should be able to buy motor, trans (t-56), wiring harness, ECM, accesories, etc out of a camaro/ firebird just about anywhere.
I fought this battle with DMV over a friends car in MD. If the emissions package being swapped in is intact with nothing missing, it's legal. Most newer GM vehicles don't have EGR anymore.
Re'
