416 l92 in a 92 miata what about headers??
looking for headers for my swap its a 416 with ported l92's. the old car want 10.87 on the motor in a gto looking for 9's all motor in my miata any help on who makes or has headers let me know thanks mike
Robert might can help answer that...
https://ls1tech.com/forums/member.php?u=104562
https://ls1tech.com/forums/showthrea...979&highlight=
You will need to make them. Go to my site and take alook what I did to solve my header problem. www.ls1miata.net. This ? has also been posted at www.miataforum.com under the engine conversion section.
1bigcam. I had a friend build the ones on mine. 1-7/8 to 3.0" collector, fit like a glove...on OJ. Anyway, be sure they're built with plugs and wires mocked up into position to give you the clearance you'll need. Everything will definitely be fighting for room. I don't have enough room for the metal shields over the stock type plug wires, but I had the headers jet hotted and then put the Taylor jackets over the wires. So far so good, but the jackets are sooooo close, I would've liked more room, but it would've been at the expense of a larger dimple in the promary.
Sounds like an awesome setup, I was heading down that route before I did the latest engine, but I couldn't ignore all of the spares that were laying around that were 346 compatible so I did that for the moment. I figured it would be fine now as I test the car to see what needs to be changed or adjusted. I knew power wasn't going to be something that needed improvement immediately. These cars are an absolute hoot with LS power!! Let me know if you have any questions about anything.
