Chevy II guys...Progress on LT's in stock clip
Made some progress on the passenger side long tubes today. Can you say TIGHT? This is my first attempt at building headers, and so far has been better than expected. A little patience, and a LOT of tubes and you too can build a set!
Drivers side is done except for the finish welding of the collector and flange.
http://good-times.webshots.com/album...acNjI?start=12
Starts on page 2, continues on page 3.
Jack
Jack
Looks like you are doing a good job for your first set of headers,your using the stock frontend arent you?Thats really tough,they are bad enough with a regular small block.My headers should be a little easier as I plan on using an after market clip.I keep hoping some one will build a set of headers for this application before I have to tackle it.Keep us posted I am watching your build with intrest.
SUPERBOOST, Chris Alston's Chassis Works makes a nice clip for these cars and Lemon Headers makes headers for an LSX install in their clip. They are rather $$$$ however but worth looking into IMHO.
http://www.lemonsheaders.com/
D.J.
D.J.
Jack
D.J.
D.J.
Thats what I'm saying too! I dont mean to sound like I think it easy to build them because I know its not,but how hard can it be with after market clip with rack and pinion.If you run an automatic or even a five or six speed with a hydraulic clutch there is just not too much in the way.They build headers on much tighter chassis than this.
Yes you really have the tough job,building those headers on a stock chevy II front end. anyone thats worked on deuces much knows that has to be tight.I may have missed it in an earlier post,what trans are you going to run?Keep us posted and good luck with your headers,you will need it!
Yeah keep the pics coming! I am just now starting to gather parts for my 66 Chevy II/LS1 6spd swap. I have the 66 & a 2000 Z28 parts car. I am in the "planning stage" right now, getting all of the info I can before I start. I am going to use a modified stock front end.
Jack
Nice work! Bet you'll be glad when they are done? I see a jig and some extra cash flow in your future! Too bad none of these old cars are the same though someone would be all bent when his hit the shock tower! How much longer are you thinking?
There is no real way to make these fit all 1st/2nd gen novas. Way too many variables to deal with. My mounts are moved 1 inch forward from stock location to facilitate clearance in other areas. I wish I could make some extra cash, I am going broke doing this conversion. I have about $350 in the headers at this point, and I still have to get them coated!
Jack
Jack
Jack
Jack
Duane,
I got the flanges from 1slow4dr from steves site for 50 bucks shipped. Speedway motors has weld up header kits with 1 /34" tubes for $104(SBC style) they come with nice long collectors. Speedway also had a box of mics bends for $79. I then had to buy more, but I bought 4 combo bend pipes at 14 each. These pipes have a 180 bend, and a 90 bend. With shipping and everything I am at approx 330. I then bought the o2 bungs from summit, that another 30 bucks (3 bungs and a plug). So I am right at 350-360. If you want to figure in electricity for the chop saw and the welder + gas, well then we add another $100 easily.
Honestly Duane, you definitely have the welding skills and the talent, I say go for it! It takes patience and time, but I think it is worth it. The 1 thing that I wish I had was a bender of some sort to make minor tweeks to some pipes. It can be difficult to get angles correct with just 45's and 90's. I sent you a PM with some good links for cheaper parts.
Jack
Jack
I know you had to build yours Jack but do you think it is worth the time and effort for the gains Duane would get for building his own, over just using the shorties? There are some pretty fast cars on this site with stock manifolds. Just wondering anyway? I don't know about you Duane but my car has been down so long I just want to get it done and not fab anything! Maybe later on build some better or buy some when the prices are down a little.
This 66 I have now has never been up for me, and still needs paint and interior work, so, I have time.
