Is any of this harness of any use ?
Wanted to get some more eyes on this harness before I return it or resell it.I was told this was a "complete engine compartment harness from a 2000 Z28 Camaro with ABS".I purchased it with the intent to pull an engine harness out of it.Is this of any use for my LQ4/65 Chevelle swap?
Thanks
Thanks
Its hard to tell exactly what all is included in that harness because the picture isn't that great of quality. I do see a fuse box for sure which may be useful for providing power to the computer and engine harness. Also, looks like there are some long connectors right by the fuse box that would plug into the computer if so that harness would be the one you need to run the engine.
I am running a 200R4.From your sig you are running a 200R4 too? Did I read correctly use fabbed your own kick down linkage?What cable did you use for the 200R4 transmission.Are you running a LS7 now?
It's an LS1 with the Professional Products 96MM intake and a 90MM throttle body. Here is a thread about the tv cable mount. The cable is a Lokar piece.
https://ls1tech.com/forums/generation-iii-external-engine/791429-tv-cable-throttle-cable-bracket.html
