Few questions. LS1-T56 into SN95
Where can I get a clutch line? Obviously it needs to hook up from the stock slave cylinder line to the GM slave cylinder on the T56. Or even direct from the clutch master cylinder to the gm slave. Even if anyone knows the fittings needed to connect to each and I could make a custom line.
Radiator Hoses, any off the shelf ones that fit to the stock Mustang radiator (is the v6 radiator good enough)?
Power Steering lines, anyone make adapters to go from the factory ford lines to the GM pump? Or custom lines?
Thanks
Thanks
power steering lines i would suggest making custom lines. As for the braided lines for the clutch, my local parts store didnt list a line, you had to buy the whole clutch master to get just the braided line.
