lq9 into 2000 ram air and now having problems, need help asap
ok i put in a lq9 motor in a 2000 trans am.. and i got all the adapters, connectors etc to make it work,, i fired the car up and the tach isnt working and the car runs rough,, ses comes on, and the car has no trottle response.. here is the thing where it gets crazy,, when i disconnect the plug for the cam sensor , it makes no difference,, but when i take a scanner and clear the codes for like 3 seconds the tach will work and cars trottle will be perfect, then throws the code and im back where i started.. does anyone have any idea what can it be? at first i thought there was something wrong with the motor, but obviously there isnt if when i clear the codes the car runs perfect for 3-4 seconds and then goes back to running like ****,, why would the tach work when i clear the code and as soon as 343 code pops up the tach stops working? anyone think it can be a computer problem.. i did put the ls2 cam sprocket because with the lq9 sprocket i couldnt switch cams.. is it possible that i have the wrong cam sensor and its reading wrong? or the wrong sprocket? thanks for your help..
ls2 cam sprocket is different and will possibly throw off the reading and make the car do what its doing. I say swap in a stock LS1 style cam sprocket and call it a day. If you've ever seen the timing cover and sprocket of LS1 vs LS2 or anything modern that has the LS2 style stuff, then yea it will read incorrectly, the car is meant to read and work off the older style stuff. Hopefully that is all and that is in fact the problem, hope you find it!!
