ls1 into 1989 suburban
Old 05-04-2008, 07:27 PM
nandofabricado's Avatar
Default ls1 into 1989 suburban
what parts will i need to drop an ls1 into a 1989 suburban
we want to use the 700r4 just tryin to keep it simple
where can i get mounts, brackets, etc.
Old 05-05-2008, 06:46 PM
anyone?
Old 05-05-2008, 07:40 PM
pcmcobra's Avatar
http://brphotrods.com/Truck%20LS1.html
Old 05-05-2008, 09:35 PM
SmokedOutZ28's Avatar
Check out Ls1trucks.com I was thinking about doing the same thing in my burban then decided it would be much better in the f-body and the LT1 can go into the burban!
Old 05-06-2008, 12:47 PM
Elec87's Avatar
If your going to install the engine into the chassis with the existing transmission I would suggest using the 1" setback mounts that we sell, You can also use your existing converter with the addition of a crank spacer and bolt kit..... The tv cable bracket can be purchases through advance adapters or s@p.
http://carshop.carshopinc.com/produc...457/C/S%202370
Old 05-06-2008, 03:56 PM
Do these brackets allow the use of the Stock Transfer case and drive shaft? If Im not mistaken the 4x4 needs to be changed for something newer when switching
Old 05-07-2008, 10:03 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
My 1 inch sebacks would get you close but I fear will not mate right to the trans, you may fall about a 1 inch short. You could either move the mounts on the chassis and redrill the holes or weld in new lower mounts. Just a few options, I would drop it in bolt it to the trans then dictate where the mounts need to be.....
Old 05-07-2008, 01:54 PM
I will definitely have to check those out
Old 05-07-2008, 03:29 PM
any ideas on headers for it
Old 05-07-2008, 03:31 PM
what if we use the mounts with the existing holes in the k member and just fab a new crossmember for the tranny?
Old 05-10-2008, 11:39 PM
wildmanaaron's Avatar
I have their engine mounts in my 1981 Blazer K-5. The fit great. The engine is in a great location on my crossmember. I already had a 700R4 transmission in my Truck and didn't have to move the tranny crossmember any.
I just need to see how much I am going to have to notch for the A/C compressor now.
Quick Reply: ls1 into 1989 suburban
