Which fuel pump should buy??????????
The stock fuel pump which flow 88-95 lph. I want to repleace it with higher flow, so what number do u advice me to buy? pumps are available in 110, 155, 190, and 255 lph versions. the engine will have cam mostly in the future not now?
255 lph should be good enough for over 600hp.
BSFC ~ .5 meand 600hp * .5 = 300 lbs of fuel per hour
to convert pounds of gasoline to liters, divide by ~1.6
300/1.6 = 187 lph
I went with the 255, even though my head/cam LS1 puts out less than 500. You never know when a built LS2 comes a-knocking on my garage door.
300/1.6 = 187 lph
my pump
I went with the Walbro 255lph with a stock TPI 305. It was regulated pressure, and knew eventually I would want more power. I am glad I did, because when I swapped in my LS1 a year later, which wasnt planned, I didnt need to worry about upgrading my fuel system.
