Do I need to connect TCC-brake cable
Old 06-14-2008, 04:46 PM
Ram Air IV's Avatar
Default Do I need to connect TCC-brake cable
So I have swapped to a LQ9 engine in my -68 Firebird and now I wonder if I most connect the TCC break switch signal/Cruise control release signal (420, purple) even if I donīt use the cruise control? Does the PCM use this signal for something else ? M
Old 06-14-2008, 05:17 PM
pcmcobra's Avatar
hmmm, dunno what color or # mine was, but on my 6.0/4l80e I have a reworked speartech harness, one wire was labeled brake switch, I had to hook it up via relay to my brake switch. I am guessing this unlocks the converter. I'm not using cruise.
Sorry if this info is of no use.
Old 06-14-2008, 06:48 PM
dhutton's Avatar
The trans needs this signal to unlock the converter. You'll need a relay or a new switch that has two sets of contacts, one normally open and the other normally closed.
Here is one option:
http://216.25.99.66/newhtml/brakeswitch.html
Don
Old 06-14-2008, 06:53 PM
rockytopper's Avatar
here ya go 17$
http://cgi.ebay.com/ebaymotors/TCC-B...spagenameZWD1V
Old 06-15-2008, 07:52 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
This is probably why your engine is stalling.
Andrew
Quick Reply: Do I need to connect TCC-brake cable
