can a gm 1500 hd harness be used for swaping or will their be to many cpu issues??
Old 07-09-2008, 06:37 PM
hemi etr's Avatar
Default can a gm 1500 hd harness be used for swaping or will their be to many cpu issues??
the harness is drive wire and that gets just a bit costly to hook-up (peddle sep. cpu,trans hook-up ). so i guess the real ? is can this be used with a throtle body set-up or not?
Old 07-10-2008, 12:35 AM
sawzall wielding director
G-Body's Avatar
You can use the harness but you will have to modify it for a cable TB. Delete some of the fly by wire wires, and add wires for the TPS sensor and IAC.
