GTO MLPS/Neutral Safety Switch Wiring Pin Out
I need the pin out for the MLPS/Neutral Safety Switch, the MLPS is bolted to the transmission on the driver side, and of course the harness plugs up to it. Hopefully someone on here has them. I am using this cluster 92123211, and I found out it maybe for a manual transmission, but still not sure. https://ls1tech.com/forums/conversions-swaps/953531-needed-2006-07-gto-gauge-cluster-wiring-pinout.html Also when it leaves the MLPS where does it connect to besides the cluster? Power? Ground?
Thanks Art...
Thanks Art...
Connector Part Information
• 9223-6722-30
• 12-Way F (BK)
Pin
Wire Color
Circuit No.
Function
1
GY/BU
275
Park Neutral Position Switch Park Signal
2
Not Used
3
YE
1479
A/T Neutral Signal
4
YE/RD
772
Transmission Range Switch Signal B
5
BU/WH
771
Transmission Range Switch Signal A
6
GY
773
Transmission Range Switch Signal C
7
BK/RD
450
Ground
8
WH
776
Transmission Range Switch Signal P
9
Not Used
10
L-GN
24
Backup Lamp Supply Voltage
11
BN/BU
239
Ignition 1 Voltage
12
GY
434
Neutral Safety Switch Signal
- instead of replying in the other thread ill post it here:
the GM numbers correspond to the color of the IPC face, the re-builder we send the clusters out to would program them for the vehicle, but if its in a swap vehicle it wouldnt really matter.
IPC = Instrument Panel Cluster, since im not ordering one they are very vauge on the info they give... you're just using it for the gauges, basic hi beam indicator/turn indicators and SES light im guessing?
If you need a new cluster let me know. I have an 06 GTO Cluster with the silver/brushed aluminum gauges and the factory pigtail for it that I need to sell. Beautiful cluster IMO. That pigtail was a MAJOR PITA to find though.....
Dave
Dave
