2007 Gmc vortec max bad engine
Old 09-30-2014, 07:26 PM
jld1980's Avatar
Default 2007 Gmc vortec max bad engine
I have a new body style Vortec max with a L76 engine that has seized up. I am looking to replace the engine but the price of a used L76 engine is crazy high. I am thinking of using an lq9 engine that is a lot cheaper. I figure I'll have to get the ECM flashed for it but is there anything else that would be a problem with doing this? Also if yall know of an easier engine to replace it with let me know. Thanks JD
Old 10-01-2014, 08:25 PM
Project GatTagO's Avatar
Received 1,404 Likes on 886 Posts
I believe the L76 is a Gen IV engine. It will be much easier to stay with another Gen IV engine. Pick any engine that is 2006 or newer and it should be an easy swap.
Andrew
Old 10-03-2014, 05:50 AM
jld1980's Avatar
Andrew
Ok. Thanks. The ly6 is the generation IV?
Old 10-04-2014, 07:53 AM
Pocket's Avatar
Yes
Easy way to split the generations is by the crank sensor. Black GEN III Gray GEN IV
What are you doing with the old engine? Ill buy the core/heads if you dump it
Old 10-04-2014, 08:06 AM
jld1980's Avatar
Originally Posted by Pocket
Yes
Ok. As far as the old engine. I had a lq9 located but I'm having trouble finding a ly6 so I may end up trying to find someone to rebuild it if I can't find anything. I'll let u know if I do get rid of it though.
Quick Reply: 2007 Gmc vortec max bad engine
