wolfe roll bar, lt1 ls1 different? or the same?
i got a local guy selling his vert roll bar and he says it is for a 98-02 car. im assuming it will also work for my 97 vert? anyone know for sure? thanks!
On their website, all their rollbars are labelled as being for '4th gen F-body', so it sounds like it should work for all 93-02 F-bodies or else they would've said '98-02 F-body'.
The LT1 and LS1 & V6 all use the same roll bar, doesn't matter which engine it had. The 4th Gen Convertible is a different roll bar than for the Coupe though. A convertible with fit any year 4th gen Convertible and the Coupe will fit any 4th gen year coupe.
thanks dan! will i have to worry about anything when drilling holes in for the bolts? I've heard some horror stories such as drilling a hole right into the fuel tank, etc. I'm sure this isn't the case w/ the f-body but is there still anything i should worry about or is it pretty much just a bolt in and go thing?
