hinson turbo kit
hinson turbo kit
I just purchased a hinson single turbo setup for my 98 c5 having trouble with the down pipe hitting the coil packs . Hinson has put the kit on a 02 zo6 just wanted to know whats the differance between the cars and if there"s a easy solution.
hinson turbo
I have the same set up. Zo6 coils are a litle different then stock ones, but i had the stock ones u have to take one screw out of the coil closest to the turbo loosen the other one and turn the coil so its not in the way. It works but still is tight, i wrapped mine with heat wrap just in case.
