Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c6 z06 busted rearend
Old 10-29-2010, 07:16 PM
Redcorvette2000's Avatar
Default c6 z06 busted rearend
So I just got my 06 z out of the shop with a new twin disc and took it to the track....BOOM...Assuming my rearend is busted....What the hell do I need to do...Looks like its an output shaft what won't know til later and I don't know **** about rear ends so. Anyways is there a beefier unit I can buy or what I mean I thought the one I had was bullet proof damn...And how much am I looking to spend worse case scenario.... Matt
Old 10-29-2010, 08:18 PM
SilveradoSS500's Avatar
Oh Dear!
PM Sent.
I assume you were drag racing? What twin disk?
Old 10-29-2010, 08:30 PM
DBN
DBN's Avatar
The C6 Z06 diff is very strong and has been tested with well over 1000 rwhp but any diff is subject to breakage given certain conditions (wheel hop, etc.). Do you have the diff and trans braced together? Send it to RPM for inspection and rebuild.
Old 10-29-2010, 09:15 PM
clint195's Avatar
Agreed
Old 10-29-2010, 10:24 PM
Originally Posted by SilveradoSS500
Oh Dear!
PM Sent.
Thanks for the pm....And yes 4,000 launch sticky *** hell track with 20psi nt05r drag radials.(spec twin)...And again no fluid leaking is a good sign but the chewed up parts werent......And to all it does actually drive a little(i tested it it when i got it off the tow truck)
Old 10-30-2010, 11:58 PM
Chevy406's Avatar
time for some 300M hardened output shafts. Been there and done that.
Old 10-31-2010, 03:44 PM
haha no fun is it....I hope thats all it is tho, lets keep our fingers crossed!
Old 10-31-2010, 09:22 PM
BlownVette 2001's Avatar
Could be the axle shafts or a broken mainshaft in the tranny. Only way to know for sure is to pull it apart.
Old 10-31-2010, 11:19 PM
I dont know but well see in da morning.I will post as soon as i find out
Old 11-01-2010, 05:45 PM
OKcruising's Avatar
I found your problem righttttt there!
Hope you get back on track soon!
Old 11-01-2010, 06:34 PM
haha no more popping the clutch.....Broken half shaft...Gm for one axle 500 plus 25 for the new seal bc it broke off right before the tranny....I think im going to just throw a gm axle on it instead of a 2399 upgrade kit from rpm....Screw that..maybe later....
Old 11-02-2010, 07:04 AM
C5 half shafts are suppose to be stronger than the C6 ones. Look for someone parting out a C5.
Old 11-02-2010, 10:00 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I never drag raced my C5Z, but I've always assumed that you could not dump the clutch with a sticky tire and a stick shift Vette without breaking stuff.
Old 11-02-2010, 10:09 AM
Maybe on stock drivetrain, but with a built drivetrain you can dump the clutch.
If you're into drag racing you're much better off with an automatic than a stick.
Old 11-02-2010, 10:59 AM
BT03mach-1's Avatar
so c5's will fit a c6? i may buy a set for back up.
Old 11-02-2010, 11:02 AM
Yes they fit.
Old 11-02-2010, 10:34 PM
Well when you build almost your entire motor and throw a twin disc clutch in for good measure you tend to wanna see what it will actually do...Believe it or not when you are talking to most people not included in the conversation is you need stronger half shafts and **** like that...Bottom line is when you are building a street car for the strip **** is gonna break until it makes the complete transition from street to the strip............Thats why when you go to the track for test and tune on friday night most of the insane fast rides are "pieces of ****" imo.......However we choose to be different and have something absolutely bad *** and different from those doing those same things...It takes a lot of time, dedication, and money....Bring on the challenge! I want the best of both worlds and i guess i will pay the price for it...I think anybody can buy a piece of crap and put a big motor and drivetrain in it and go fast...But for us "Vette boys" we are starting off 20-60k in the hole....So in conclusion, i salute all you with vettes running crazy ets........
Old 11-03-2010, 06:10 AM
NoTractionLS1's Avatar
True that!
Old 11-04-2010, 06:53 PM
Luckymex_dallas's Avatar
<< broke three halfshafts...and these are the suppposed 1000 HP 300M shafts...
sticking with the stock one now it ran a 6.70 i. the 1/8 l;eaving at 3500 RPm on 20 PSI nitto nt05
until i break em again going to have to upgrade to the RPM package, but hey at lreast you get a year warranty.
Old 11-04-2010, 10:27 PM
I heard that and thats a pretty good et....But from what i hear you can **** up your rearend and tranny...When they were fixing my car they had to use a magnet to suck out some of the **** out of my transmission bc thats where it broke at..........I think it can get pretty ugly and i got lucky
Quick Reply: c6 z06 busted rearend
