Leaky Rearend
Leaky Rearend
My wife's '98 Vette is leaking grease at the rearend.
I have not jack it up yet to look at it (lazy). I know nothing about this transaxle setup. Is this a self-contained unit? Can I add grease/transmission fluid or what. Hell, I can't even find a trans dip stick. Please help, she's on my ***.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
The left (driver's side) cover on the rear is most likey your problem. It needs to be removed & sealed with RVC Silicone.
(and replace the axle seal)
Here, I did a search for you. BTW- no dipstick in trans either
http://mysite.verizon.net/res0aae8/diff.html
http://mysite.verizon.net/res0aae8/tranny.html
P.S.- You should look for a Corvette shop in your area instead of the stealership.
