Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
New 427 almost done what do u h think she will do
Old 02-15-2011, 05:25 PM
racerrob333's Avatar
Default New 427 almost done what do u h think she will do
Me and Chris from Hunter performance solutions decided to use Proline to build us a motor for me vette. We will be going with a f2 procharger most of the time and a f1a for the lsx shootouts.We also will be running the east coast performance powerglide. So what do ya think she will run and what rwhp do u think we will be at?
Here is a least of everything in the motor
FLASH HONE W/ TORQUE PLATE V-8
ALIGN HONE BLOCK W/ 4 OR 5 MAINS
MACHINE BLOCK DECK SURFACE V-8
BLOCK PREP: CHAMFER BOTTOM OF CYLINDERS/ DEBUR BLOCK/ HONE LIFTER
BORES
INSTALL FREEZE PLUGS
8 PIN FIT RODS
BALANCE COMPLETE ROTATING ASSEMBLY V-8
MACHINE & INSTALL SPACER FOR CAM SENSOR FOR RHS BLOCK
JET CLEAN COMPLETE ENGINE PARTS V-8
ASSEMBLE COMPLETE V-8 RACE ENGINE
CHECK & LAP VALVE JOB
2 SURFACE CYLINDER HEADS V-8 (PER HEAD)
SET SPRING HEIGHT & ASSEMBLE CYLINDER HEADS V-8
RHS LS ALUMINUM RACE BLOCK 4,840.00 4,840.00T
CALLIES LS1 DRAGONSLAYER CRANKSHAFT 4.00 STROKE 2.100 ROD JOURNAL
2.559 MAIN
1,312.69 1,312.69T
OLIVER BILLET SBC CONNECTING RODS 1,199.00 1,199.00T
8 DIAMOND SB / INLINE VALVE CUSTOM DISH PISTON
8 DIAMOND GAS PORTING - SIDE (UP TO 12 HOLES)
8 DIAMOND PIN FIT 8.00
8 DIAMOND H-13 WRIST PIN .927x2.950x.225 WALL T
CLEVITE/CALICO SBC COATED PERFORMANCE MAIN BEARINGS
8 CLEVITE/CALICO SBC COATED PERFORMANCE ROD BEARINGS
TOTAL SEAL CUSTOM RING SET
COMP CAMS CUSTOM CAMSHAFT
COMP CAMS RHS LS1 HEX ADJUST TIMING SET
JESEL LS SERIES .842 SOLID BODY ROLLER LIFTERS (CENTER/CENTER) 1
Page 1
Estimate
Date
1/4/2011
Estimate #
4613
Name / Address
Robbie Clark
Customer Rep
Matt
Engine
RHS 427
Prices subject to change without notice. Pro Line Racing has no warranty expressed or implied
beyond the warranty of the manfacturer(s). Most parts (not all) come with a limited
manufacturer's warranty on the parts ONLY. This warranty DOES NOT include labor costs for
installation, removal, and/or shipping. No refund on ANY products, only in house credits will
be issued. All returns must have an RMA# before being sent back. No credit will be issued for
damaged merchandise. 20% restocking fee applies. NO EXCEPTIONS.
Total
Subtotal
Sales Tax (0.0%)
Pro Line Racing LLC
116 Dixie Drive
Woodstock, GA 30189
Phone: 770-516-0745
Fax: 770-516-0729
Quantity Description Price Each Total
MELLING HI VOLUME PUMP FOR LS1
MAST MOTORSPORTS CATHEDRAL PORT 275CC 12 DEGREE, 4.125"-4.200" 6-BOLT
LARGE BORE CNC, BARE
2 MAST MOTORSPORTS ROCKER STAND BOLT UPGRADE (PER HEAD)
8 MAST MOTORSPORTS 2.200" 5/16" PREMIUM SOLID STEEL RACE VALVE 5.450"
8 MAST MOTORSPORTS 1.600" 5/16" PREMIUM SOLID STEEL RACE VALVE 5.450"
MANLEY NEXTEK VALVE SPRINGS 280LBS@2.100
MANLEY VALVE SPRING SHIMS
MANLEY VALVE SPRING LOCATORS
MANLEY TITANIUM RETAINERS, 10 DEGREE
2 MANLEY LOC-10 DEG .3415 BEAD TITANIUM
16 SMITH BROS 3/8 .145 WALL 4130 HEAT TREATED PUSHRODS T
JESEL ROCKER ARM SYSTEM FOR MAST 12 DEGREE HEADS
MOROSO/PRO LINE RACING BLACK ANODIZED VALVE COVERS (C5R) 475
ARP LS-SERIES OIL PAN STUD KIT
ARP LS-SERIES BALANCER BOLT (EXCEPT LS7)
ARP 2000 LSX 6-BOLT PER CYLINDER HEAD STUD KIT
GM LS1 REAR MAIN SEAL
GM LS1 OIL PAN GASKET
GM LS1 TIMING COVER GASKET
COMETIC GM LSX LEFT HEAD GASKET
COMETIC GM LSX RIGHT HEAD GASKET
16 .470 x 5/16-11/32 VALVE SEAL 2.99 47.84T
SHOP SUPPLY CHARGE (5% OF LABOR. MINIMUM $3.00, MAXIMUM $25.00) 25.00 25.00
PLUS FREIGHT CHARGES FOR INCOMING PARTS
Page 2
Old 02-15-2011, 05:33 PM
WKMCD's Avatar
Looks like some good stuff. Let us know.
Old 10-24-2021, 06:13 AM
lsoutlawz's Avatar
Default Hope it runs good let us know what she runs
Hope she runs good let us know
thought these came with a Bryant crank shaft this engine is close to what I have but I’m curious cause I didn’t know they built these and I know these guys are top notch
Old 11-22-2021, 08:18 AM
grinder11's Avatar
racerrob333, did you get it running, or go to the track yet?
Quick Reply: New 427 almost done what do u h think she will do
