found a simple cheap way to fill the transmission
http://www.amazon.com/Sprayco-Long-R.../dp/B000VYGCZW
works on an A4
I'm thinking it should work on a manual
I just used a heat gun to make the tube bend the way I needed it so it would fit.
I doubt it would work with 90wt but dexron flows easily and it worked to perfection
found one at a local hardware store for 4 bucks
FYI : the tube goes to the bottom so you just squeeze it to make it work
HOLDS 2 QTS.
works on an A4
